High-Speed Digitizers
USB 5133 light install
Hi all,
there is way to install the minimun of application just for have a visualisation like a portable scope ?
I don't need all the stuff for my use, there is a lot of program that run in background of windows.
I just need to have an application like ni-scope front panel.
The install package (4.0) is heavy cost 1.7gB. Because is universal for many instrument tool from NI.
thanks
good afternoon
(5,753 Views)
Unfortunately that is the only installer currently released on its own, and we don't have a separate installer for the NI-Scope Soft Front Panel.  There is a way to create an installer that has just a subset of the full NI-Scope driver.
When you create an application, you can deploy it and create an installer for it using the Application Builder.  This allows you to package your NI-Scope program with the NI-Scope Run-Time Environment.  When using this custom installer, you would not need the full NI-Scope driver installation on the deployment machines.
I hope this helps.
Systems Engineer
SISU
(5,719 Views)
