High-Speed Digitizers
Using PFi line as trigger for NI 5133
I am trying to use NI 5133 for collecting data for 2 channels at 1 MHz sampling rate. This data is being collected on an engine and I need a reference point for my signal. Can I use PFI channel as an external trigger? I will get a TTL pulse whenever there is a sparking event and I want to start acquisition at this point and collect data for 1 Sec. Can I connect my TTL signal as trigger.. also I need to use only the first high to be treated as trigger and collect data for 1 sec... Please help me out in this.. a bit urgent...
Anil
(7,052 Views)
hi!
what you have described here is similar to my usage.  have you resolved it?  i need some advices.
(6,759 Views)
Hi Anilvs and Shefsteele,
Please can I direct you to this post if you still have trouble getting this to work.
Regards
JamesC
NIUK and Ireland
It only takes a second to rate an answer 🙂
(6,651 Views)
