High-Speed Digitizers
Using two digitizers simultaneously (5133 and 5132)
Hi
I need to collect data on 3 channels simultaneously at a sampling rate of 1 MHz and for a duration of 1 sec. I do not have a 4 channel system right now and planning to use two high speed NI digitizers - NI 5133 and NI 5132. I have written a code in Labview 8.5 and attached the same herewith. I am planing to use one of the chennels as analog edge trigger. Will this work and if so will there be any problems with synchonisation. Please let me know whether the acquisition for all the three channels be simultaneous or will there be any lag or error for the second digitizer.
Anil
Message 1 of 1
(6,439 Views)
