High-Speed Digitizers
Where can I get driver for hp54750A Oscilloscope for LabView 6.0 version?
Would it be possible for someone to give me the driver for a hewlett packard digitizing oscilloscope model no. hp54750A. Thanks very much
(6,231 Views)
unfortunately, I couldn't find a driver for this Oscilloscope, on our website, or on Agilents, that I could convert for 6.0. (If there was a cvi one, then I could convert that).
You need to use the programmers manual to work out the calls you need to make through GPIB (or serial if that's the interface you're using) and effectively write your own.
There is a request a driver page here , however there's no guarantees that we could get the scope to make the driver in a reasonable time frame.
I checked the web too, but no-one seems to have listed a labview driver for that oscilloscope either.
I'd suggest starting with the examles in LabVIEW for gpib (or serial) comms and testing out the fact that you can ge
t communication in the first place, then work on the commands that you need first.
The programmers guide can be found here. I shan't attach it since it's 2MB in size!!
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(6,230 Views)
