High-Speed Digitizers
Why niScope_FetchBinary16 is slow for some sampling rates
I was trying to profile application fetching data from NI 5124 PXI digitizer.
Starting from example code in BinaryAcquisition and using VisualStudio 2008 C++ Net Express edition I made test application
and measured the time spent in niScope_FetchBinary16 called in loop.
The result is strange to me. I have summarized it in table.
Sample rate (Sr) || Namber of point to fetch (N) || Averaged time spent in function (T), ms || theoretical time of scan = N/Sr, ms
200 Ms/s  ||  2000  ||  0.22 ms     ||  0.01ms
  20 Ms/s  ||  2000  ||  0.22 ms     ||  0.1ms
    2 Ms/s  ||  2000  ||  8.9 ms       ||  1 ms
200 Ks/s   ||  2000  || 19.1 ms      ||  10 ms
  20 Ks/s   ||  2000  ||  109.78 ms || 100ms
It looks to me that difference of two times ( T - N/Sr ) should be approximately same for all sampling rates because number of points N is constant.
That contradicts with measured results.
Can some body reproduce these measurements / explain results to me?
The following is code I have used:
// test.cpp : main project file.
#include "stdafx.h"
#include <string>
#include "niScope.h"
#define MAX_STRING_SIZE 100
using namespace System;
ViStatus _VI_FUNC niScope_GenericBinaryAcquisition (void);
int main(array<System::String ^> ^ /*args*/)
    Console::WriteLine(L"Start Test niScope_GenericBinaryAcquisition");
    System::Diagnostics::Stopwatch^ stopwatch = gcnew System::Diagnostics::Stopwatch();
    stopwatch->Stop();
    stopwatch->Reset();
    stopwatch->Start();
    ViSession vi;
    // Variables used to get values from the GUI
    ViChar resourceName[MAX_STRING_SIZE] = "Dev1";
    ViChar channelName[MAX_STRING_SIZE] = "0";
    ViChar ansiOptionString[MAX_STRING_SIZE] = "Simulate=0,RangeCheck=1,QueryInstrStatus=1,Cache=1";
    ViReal64 verticalRange = 10.0;
    ViReal64 verticalOffset = 0.0;
    ViReal64 minSampleRate = 200000000.0;
    ViInt32 minRecordLength = 2000;
    ViInt32 binaryDataType = 2; // bin16
    ViReal64 refPosition = 50.0;
    ViReal64 timeout = 15.0; // seconds
    ViInt32 numWaveform;
    ViInt32 actualRecordLength;
    ViReal64 actualSampleRate;
    // Waveforms
    struct niScope_wfmInfo * wfmInfoPtr = NULL;
    ViReal64 * scaledWfmPtr = NULL;
    void * binaryWfmPtr = NULL;
    // Open the NI-SCOPE instrument handle
    if( VI_SUCCESS != niScope_InitWithOptions( resourceName, NISCOPE_VAL_FALSE, NISCOPE_VAL_FALSE, ansiOptionString, &vi ))
        return 0;
    // Configure the vertical parameters
    if( VI_SUCCESS != niScope_ConfigureVertical( vi, channelName, verticalRange, verticalOffset, NISCOPE_VAL_DC, 1.0, NISCOPE_VAL_TRUE ) )
        return 0;
    // loop over sampling rate
    for(int i = 0; i < 10; i++)
        Int64 mss1;
        Int64 tiks1;
        Int64 mss2;
        Int64 tiks2;
        Int64 dmss = 0;
        Int64 dtiks = 0;
        String^ mess;
        // Configure the horizontal parameters
        if( VI_SUCCESS != niScope_ConfigureHorizontalTiming( vi, minSampleRate, minRecordLength, refPosition, 1, VI_TRUE ) )
            return 0;
        // Configure the trigger
        if( VI_SUCCESS != niScope_ConfigureTriggerImmediate( vi ) )
            return 0;
        // Find out the number of waveforms, based on # of channels and records
        if( VI_SUCCESS != niScope_ActualNumWfms( vi, channelName, &numWaveform ) )
            return 0;
        // Query the coerced record length
        if( VI_SUCCESS != niScope_ActualRecordLength( vi, &actualRecordLength ) )
            return 0;
        if( VI_SUCCESS != niScope_SampleRate( vi, &actualSampleRate ) )
            return 0;
        // Allocate space for the waveform ,waveform info, and binary waveform
        // according to the record length and number of waveforms
        wfmInfoPtr = (struct niScope_wfmInfo*)
            malloc (sizeof (struct niScope_wfmInfo) * numWaveform);
        binaryWfmPtr = (void*) malloc (binaryDataType * actualRecordLength * numWaveform);
        scaledWfmPtr = (ViReal64*) malloc (sizeof (ViReal64) * actualRecordLength * numWaveform);
        // Check is memory allocations succeeded.
        if ( scaledWfmPtr == NULL || wfmInfoPtr == NULL || binaryWfmPtr == NULL )
            return 0;
        mess = L"S/s: " + actualSampleRate.ToString() + L"; N: " + actualRecordLength.ToString();
        Console::WriteLine( mess );
        // 50 repetitions of calls to niScope_FetchBinary16 function
        for(int j=0; j<50; j++)
            // Initiate the acquisition
            if( VI_SUCCESS != niScope_InitiateAcquisition( vi ) )
                return 0;
            mss1 = stopwatch->ElapsedMilliseconds;
            tiks1 = stopwatch->ElapsedTicks;
            mess = L"\t" + mss1.ToString() + L"ms" + L" (" + tiks1.ToString() + L")";
            //Console::WriteLine( mess );
            // Fetch the data according to the obtained data type
            // Use the 16 bit fetching function
            if( VI_SUCCESS != niScope_FetchBinary16( vi, channelName, timeout, actualRecordLength, (ViInt16*) binaryWfmPtr, wfmInfoPtr ) )
                return 0;
            mss2 = stopwatch->ElapsedMilliseconds;
            tiks2 = stopwatch->ElapsedTicks;
            mess = "\t" + mss2.ToString() + L"ms" + L" (" + tiks2 + L")";
            dmss = dmss + mss2 - mss1;
            dtiks = dtiks + tiks2 - tiks1;
        mess = "            Delta: " + dmss/50.0+ L"ms" + L" (" + dtiks/50.0 + L")";
        minSampleRate = minSampleRate / 10;
    // Close the session
    if (vi)
        niScope_close (vi);
    return 0;
(5,765 Views)
I have recompiled the test application as win32 console application using VisualStudio 2008 C++ Express edition.
The results are same.
The spent in fetching function time smaller by order for 20 Ms/s sampling rate than for 2 Ms/s.
If some body has ideas why is that share it with me please.
Sample rate (Sr) || Number of points to fetch (N) || Averaged time spent in function (T), ms || theoretical time of scan = N/Sr, ms
200 Ms/s  ||  2000  ||  0.25 ms     ||  0.01ms
    2 Ms/s  ||  2000  ||  9.95 ms     ||  1 ms
200 Ks/s   ||  2000  || 20.02 ms    ||  10 ms
  20 Ks/s   ||  2000  ||  110.92 ms || 100ms
The code of test is following (this forum rejects cpp code to be attached).
// ltdtestwin32.cpp : Defines the entry point for the console application.
#include "stdafx.h"
#include <iostream>
#include "Windows.h"
int _tmain(int argc, _TCHAR* argv[])
std::cout << "Start Test niScope" << std::endl;
ViSession vi;
//ViChar ansiOptionString[MAX_STRING_SIZE] = "Simulate=1,DriverSetup=Noise:4.0;Model:5124;BoardType:PXI;";
// Waveforms
// niScope_init( resourceName, NISCOPE_VAL_FALSE, NISCOPE_VAL_FALSE, &vi );
return 0;
return 0;
LARGE_INTEGER tiks1;
LARGE_INTEGER tiks2;
LARGE_INTEGER dtiks;
//calibrate QueryPerformanceCounter()
int num_of_ms = 1000;
QueryPerformanceCounter( &tiks1 );
Sleep( num_of_ms );
QueryPerformanceCounter( &tiks2 );
dtiks.QuadPart = tiks2.QuadPart - tiks1.QuadPart;
double tiks_per_ms = 1.0 * dtiks.QuadPart / num_of_ms;
int num_of_rep = 100;
return 0;
return 0;
return 0;
return 0;
return 0;
return 0;
std::cout << "S/s: " << actualSampleRate << "; N: " << actualRecordLength << std::endl;
dtiks.QuadPart = 0;
for(int j=0; j<num_of_rep; j++)
return 0;
return 0;
//std::cout << " t1: " << tiks1.QuadPart << " t2: " << tiks2.QuadPart << std::endl;
dtiks.QuadPart = dtiks.QuadPart + tiks2.QuadPart - tiks1.QuadPart;
std::cout << " Delta: " << dtiks.QuadPart / tiks_per_ms / num_of_rep << " ms" << std::endl;
if (vi)
niScope_close (vi);
return 0;
(5,752 Views)
