High-Speed Digitizers
Writing C# Synchronized Read/Write Functions
I am trying to create C# functions that will wait until the GPIB command has actually completed on the system that it is executed on.  That is, I dont want to just wait until the command has been run, I want to wait until the command is complete.  So for example, if I do a Device.Write(":INITiate:IMMediate" ) where the Device is a Spec A, I want to wait until the sweep is complete on the system before continuing in my code.  I think the Device.Wait(IOComplete) only waits for the issuing of the command to complete.  It doesnt wait for the sweep to finish (I know this because after I run Device.Write(":INITiate:IMMediate" ), then Device.Wait(IOComplete), then Device.Write(":CALCulate:MARKer:MAXimum" ), which does a peak search.  And I can see that on the Spec A, that the sweep isnt complete when the peak search is executed.
This is cutouts of the code I have so far.  I would also like to do a similar thing with Read (that is make sure the read is finished before moving on).  I feel there is a better way than what I have below (which seems to work ok, but it might just be because of the extra delay introduced by the *OPC? command.
 Board mGpibBoard = new Board(mGPIBConfiguration.GPIBBoardID);
mGpibBoard.AbortAsynchronousIO();
mGpibBoard.SendInterfaceClear();mGpibBoard.BecomeActiveController(true);
mGpibBoard.IOTimeout = GPIB_TIMEOUT_VALUE;
mGpibBoard.SetEndOnEndOfString =
false;
mGpibBoard.SetEndOnWrite = true;
Device Unit = new Device(mGPIBConfiguration.GPIBBoardID, gpibUnit.PrimaryAddress);Unit.TerminateReadOnEndOfString = false;
Unit.IOTimeout = GPIB_TIMEOUT_VALUE;
Unit.SerialPollResponseTimeout = GPIB_TIMEOUT_VALUE;
Unit.SetEndOnEndOfString =
false;
Unit.SetEndOnWrite = true;
public void SyncWrite(String command)
  if (Unit != null)
    GpibStatusFlags wait_mask = (GpibStatusFlags.IOComplete | GpibStatusFlags.Timeout);     Unit.Write(command);
    Unit.Wait(wait_mask);
    bool synced = false;
    int counter = 0;
    while (!synced && counter < 100)
      Unit.Write("*OPC?");
      String val = Unit.ReadString();
      synced = val.Trim().Replace(
"+","").Equals("1");
      counter++;
public String SyncRead(String command)
  String read_string = ""; if (Unit != null)
    read_string = Unit.ReadString();
    int counter = 0;
"+", "").Equals("1");
      counter++;
  return read_string;
Nick
(8,354 Views)
I am unaware of a direct way to program this.  In LabVIEW, we usually use a small delay between the GPIB Write and Read on the instrument.  I would recommend the same to you.  Your extra call will accomplish this, or you can program a delay directly.
Ben
Certified LabVIEW Associate Developer
Certified TestStand Developer
(8,314 Views)
The problem with delays is that they system setups the software will be running on is different.  One customer might be running a USB GPIB device, while another is using a high speed PCI GPIB device.  I would like to be able to run the set of commands as fast as possible for a given setup.  Otherwise I have to run the worst case delays, which is pretty slow (considering that what we are doing is adjusting systems, doing a scan on the Spec A, then doing a Peak Search, over and over).  If we need a worst case delay of 500ms in between each, this adds an extraordinarily large amount of time to the test.  Hoping for a programmable solution here.
Nick
(8,305 Views)
The time required to complete an operation is different for every operation on every instrumentand thus the ability to know when the operation is complete is not built into NI-488.2.  This kind of functionality would have to be instrument specific.
Ben
(8,274 Views)
