High-Speed Digitizers
Xincrement doesn't agree with sampling rate
I'm using two PXI-5114 Digitizers that are being synchronized. I am trying to take 5 seconds worth of data.  I have the Sample Rate = 1e3 and the Record Length = 5e3. I only get about 1.3 seconds worth of data.  I looked at the Actual Record Length and the Actual Sample Rate outputs and they said the same thing that the front panel did. I then looked at the Wfm info output of the NiScope Multi Fetch Cluster.vi and it had the same Record Length but the Xincrement value is 262e-6. This corresponds with the measurements I am getting.  Any ideas?
Thanks in advance.
(5,800 Views)
Accepted by topic author AT1
Hi AT1,
Thanks for posting. What you are seeing is due to the fact that the minimum sampling rate of the PXI-5114 is 3.81 kS/s. The digitizer will coerce any value below 3.81 kS/s up to that value, therefore a record of 5000 samples will take 1.31 seconds to acquire. If you are looking to acquire 5 seconds worth of data, I recommend increasing the record length to around 19,050 samples, which should roughly correspond to 5 seconds worth of data. Let me know if this would this work for your application.
Joe S.
(5,783 Views)
