High-Speed Digitizers
can't acquire 2 channels
Hi Carolyne,
Definitely in the long run you should build your own applications in LV for numerous reasons. However, I am just trying to get to the bottom of why you seem to be able to acquire from only one channel. Is this a hardware or software problem? If for example you used the Tek software and you still could only get one channel then I think  things would certainly point towards a hardware issue. On the other hand if everything is fine a dandy while using the Tek software then I think it points to a problem with your LV setup.
Also I think Tek tech support will first recommend using their software per usual if tech support can deny accountability by the fact that you are using some other product they usually will.
Cheers,
--Russ
Message Edited by Russ Evans on 05-22-2006 11:16 AM
Message 11 of 12
(3,355 Views)
Dear Russ,
The acquisition of 2 channels is actually working. I don't know exactly why I've had problems before. Maybe because of the timebase which was very tiny (10 microseconds), but now I work with a 2.5ms timebase and it's quite ok.
Thanks for your help
Message 12 of 12
(3,337 Views)
