High-Speed Digitizers
could anyone help me convert this driver created with old version to the new version labview file? Thanks
it is driver for ADC16 from PICOtech,
hoowever the file was created using labview 4.x,
I could not open it using labview 8.5, ( according to the instruction one needs to copy both adc.llb and adc1632.dll under labivew's "users's libary' folder)
could anyone help
or suggest a way to open it?
many thanks
(6,681 Views)
Here it is in version 7.1 which 8.5 can open. Not much to the code at all. You could have used Tools>Import>Shared Library to get the basic driver.
p.s. In the future, if you have any similar requests, post to the LabVIEW board. Since you are not using an NI digitizer, this was not the most appropriate board.
(6,661 Views)
Thanks so much Dennis!
Dan Richards
Dan Richards
Certified LabVIEW Developer
(6,646 Views)
Thank you, Dennis, problem solved.
(6,598 Views)
