High-Speed Digitizers
high speed sampling with analog trigger
I am a new user of DAQ card and I need to sample the analog signal with a high speed.
I will use a sinusoidal-like wave to trigger the sampling and set a voltage around the peak of trigger wave with rising slope. When the voltage arrived, I only sample one point from CH0 or CH1. The frequency of the trigger wave is about 5MHz and I heard the LabView only works at KHz level. Is it possible to use LABView to realize my application?
If it's possible, would you mind telling me how to realize? Or if it's not possible, would you mind telling me what to do? My DAQ card is PXI-5112.
Thank you very much!!!
Message 1 of 1
(6,331 Views)
