High-Speed Digitizers
how can i use ni 5122 in matlab ?
Hi all,
i want to use my 5122 card in matlab. is that possible ?
Maik
(7,159 Views)
I don't know, but i'm dying to find out!
(6,568 Views)
Hi midmaik,
We do not offer a way to natively interface our digitizers with Matlab, however, you can acquire and save the data using SignalExpress, LabVIEW, or another text based language, like C or Visual Basic that can interface with the NI Scope driver then do your signal processing in Matlab.  You might also take a look at the MathScript module for LabVIEW.  This will allow you to use .m scripts inside LabVIEW so you will be able to program your scope and perform your processing while the program is running.
NI Scope Driver
Jim Schwartz
(6,513 Views)
