High-Speed Digitizers
how do I generate a square waveform from 0 to 5 V
I have a PXI-5412 and want to generate a square waveform from 0 to 5 volts. How do I do that ?
(6,169 Views)
To add some more informtion : I am using Labview version 8.2.1, the attached Fgen_Basic_Arb_Waveform.vi, which is modified, doe not do the trick.
The waveform is still symmetric around zero, and the offset cannot be controlled at all. Also, where can I find more in depth information about creating arbitrary waveforms ?
The problem initiates by the fact that a PXI-5412 can only have an offset of 25% of the amplitude, which in my case should be 50%.
I.e. 5V amplitude (pk-pk), and 2.5 offset.
(6,149 Views)
