High-Speed Digitizers
how do i adjust veritcal range on each channel of the 5105
I'm using a 5105 to capture 4 analog signals and 4 control signals that are at different levels.  Is it possible to configure the 5105 for different vertical ranges on each of the 8 channels?
(6,138 Views)
Howdy Creed!
This KnowledgeBase article explains how to configure the vertical range per channel of your digitizer.  Hope that helps!
Barron
Applications Engineering
(6,128 Views)
Thanks.  I think that's what I was looking for except the figures are no longer available so
I can't be sure.  The text sounds like what I was looking for.  An  NI engineer found the
following:
I would recommend taking a look at the two examples that I have included.
1. The first example shows how you can set the Vertical Range independently
for different channels by using an NI-SCOPE Property Node.
http://zone.ni.com/devzone/cda/epd/p/id/2085
2 . The second example shows how you can set the Vertical Range by using
two different niScope Configure Vertical.vi with a different channel name
going to each.
http://zone.ni.com/devzone/cda/epd/p/id/4017
thanks for your help.
(6,116 Views)
