High-Speed Digitizers
i get an error when i try to use my ni 5112
When I want to use a typical digitiser application or example like one channel scope.vi I get an error at AI group config. This also happens when I want to ackuire a waveform. The device in MAX is ok, the test panels are ok. I constantly get this wessage whenever I want to use the card.
Any ideas?
(6,007 Views)
The problem you are having is because you are using an example that uses the NI-DAQ driver as the API. The One Channel Scope.vi is an example program that actually uses MIO DAQ devices and not our High Speed Digitizers. When you look at the example finder in LabVIEW, it will actually give you a list of supported devices for each VI.
To get the example programs for your high speed digitizer using the NI-SCOPE API, go to Sart>>programs>>National Instruments>>NI-SCOPE>>Examples.
Best Regards,
Jeremy R.
NI - Applications Engineer
(6,007 Views)
