High-Speed Digitizers
multi-board synchronization and AO and AI
I have 4 6110E pci cards in one PC and would like to synchronize and control both AO and AI from all 4 cards using an anolog trigger and sampling at 5 MS/sec using RTSI. Has anyone written any code to perform this task.
(5,984 Views)
I am attaching a link where you will find some examples related to multi-board synchronization.
Please do let me know if you need further help.
The path to that link is :
www.ni.com>>NI Developer Zone>>Development Library>>Measurement Hardware.
The link is :
Advanced programming Techniques
(5,984 Views)
Hi, and thank you for the location to those files. What I was looking for specifically was an example that performed both AO and AI simultaneously for 2 or > e series boards. Its seems to me that more work is necessary to correlate both AO and AI to RTSI
DO you have any examples of this type
Goober
(5,984 Views)
Hmm.
Well thats like combining Simultaneous AI/AO stuff with Multiboard synchronization. The idea that i would ive is, to see the simultaneous AI/AO example under the same link that I gave and then combine it with multiboard synchronization. For more ideas you may look at the example named "Synchronizing Simultaneous Analog Input and Analog Output on Multiple Channels" that is there under the same examples link that I provided to you in my last response.
Sincerely,
Sastry V.
National Instruments.
(5,984 Views)
The examples for the simultaneous AI/AO and multiboard synchronization are clear and easy to implement, but like the original poster, I would also like to extend the capability to combine the two together. Since this original email exchange, has such a VI been made available? Some pre-canned VIs would make life easier.
Jim
(5,984 Views)
