High-Speed Digitizers
my PC doesn't detect NI PCI-5102
Hello Guys,  I got recently an used NI PCI-5102 scope board,
 I install it immediately that board in a IBM Netvista PC 6792-24U,
(Computer Details:
Intel Pentium 4 1.8GHz (256KB), 256MB, 40GB 7200RPM IDE HDD,
PCI Desktop (4x4), nVidia Vanta 16MB 4X AGP, 48x CD-ROM,
Intel 10/100 Ethernet, POV, Windows XP SP2)
But I don't know what is wrong with it, because the Windows XP does not
detect the new hardware, even I thought maybe is something wrong
with the BIOS, but no, I update the BIOS with the most recent version and
got the same situation. Is there a step that I'm forgetting?, how can to
know if the board is good (no damaged).
NI support team, Could you tell me what can I do?
Thanks in advance.
(7,180 Views)
Accepted by topic author IvanB
Hi IvanB!
There are several steps you can do for troubleshooting:
1.- Try swapping the PCI Slot in the same PC and check if the device manager detects the device as a new PCI Hardware, it wont tell you it is a 5102 cause you need to have NI Scope installed.
2.-If it doesnt work on the same PC, try a different one and check if windows detects it and if it appears on the device manager.
3.- If that doesnt work your best option is to send the board to NI so they can check if its malfunctioning, for Mexico the free number is: 01800010793 for more information.
Hope this helps, another thing is that you can call your provider since its a used one, he should respond in case it doesnt work.
Have a great day!!
(7,156 Views)
Same problem here too. I see a "PCI device" in the hardware manager, but when I go to 'update driver software', I don't see the PCI-5102 in the list of NI hardware. The lowest 5xxx series hardware I see in the list are the PCI-5105 and PCI-5114. I have NiScope 3.6 installed, Win 7 Ultimate x64.
Any ideas?
(6,683 Views)
Sorry...shoulda started my own thread on this one since this is labeled "solved" and I think I have a slightly different issue...new thread started here
(6,669 Views)
