High-Speed Digitizers
ni scope examples
how i can get the digital data from the card PXIe-5622 to display it or save it to a file please we want solved example working on Labview 2010
thanks for your cooperation with us
(7,392 Views)
If you have installed the NI-SCOPE driver, then working LabVIEW examples should be installed onto your system at:
Start » All Programs » National Instruments » NI-SCOPE » Examples
The help file for the NI-SCOPE driver is extreemly helpful for understanding your device and how to communicate with it.  The help file can be found at:
Start » All Programs » National Instruments » NI-SCOPE » Documentation
Here is the help file download if its not found on your system:
http://digital.ni.com/manuals.nsf/websearch/86590EFAD38AE49C86256FF8007CB2B3
I hope this helps!
Systems Engineer
SISU
(7,380 Views)
hi, i am trying to get waveform info from digitizer pci-5105 in borland 2007 IDE . very simple code? but problem? it hangs when exiting on closing bracket (trying to close some threads). I am just beginer in NISCOPE API, so cant find mistake. here is a code: //--------------------------------------------------------------------------- #include //#include #include #include #include #include "niScope.h" /*********************************************************************************\ #define MAX_STRING_SIZE 50 int main(int argc, char* argv[]) { ViSession vi = VI_NULL; ViChar errorMessage[200]; ViInt32 actualRecordLength; ViReal64 actualSampleRate; int res; cout<<"Before Starting\n"; res=niScope_init("Dev1", NISCOPE_VAL_FALSE, NISCOPE_VAL_TRUE, &vi); cout<<"Session is opened?\n"<
(7,292 Views)
AdagioA,
Please post your question in a new thread.  This will increase the chance that your question will be seen by those who will be able to answer it.
Systems Engineer
SISU
(7,267 Views)
