High-Speed Digitizers
niScope EX Multi Record vi program
I have a question in niScope EX Multi Record.vi program. I was not explaining it well in my previous mail. That is why people can not answer my question. This time, I will explain clear.
Attached "abc" is my prgram with niScope EX Multi Record.vi prgram.  This is my question. How come I can not get the waveform when I do the same action in the seond time? Here is how my prgram work. First, I press "reset"  push button, the light will go off and press it again the light turn off. The prgram do nothing, just reset the value of the voltmeter and current meter. Second, I press the "enable" button, the voltmeter and current meter get reading since I have a subprgram under timeout in the event structure. Then, I press the "enable button" again to turn on the light. Third, I press the "bark button", my hardware will be shocked and output waveform, since I have a subprogram, niScope EX Multi Record.vi, I set the right parameter, I will get the "shock pulse waveform".
Everything looks good and working. Then I press the "bark" push button again to turn the light off. I want to do the same action the second time to see if the waveform of niScope EX Multi Record will generate again because normally I tried the same action the second time. the waveform will generate again. Here I am talking about I use the niScope EX Multi Record.vi prgram without anything and event structure and I did the same action as what I said in the above procedure. But, I did the same action in the second time in this "abc" vi program with niScope EX Multi Record. vi prgram, I could not get a new waveform, I don't understand why? could you please tell me what I did wrong? my niscope EX Multi Record.vi prgram is out of the event structure, what I see is like this prgram is alone just like the one I tried without event structure before. I am not sure if this single prgram mixed with event structure, it will be what? will it be different like I put two subprgrams in one block diagram even though I tried two subprgram put it together and it will work what it suppose to do. I am not very sure if ni scope EX Multi Record.vi prgram mixed with other prgrams with event struturem, what will happen? Will it be the same like two subprgram put it together? Could you please tell me exactly what if I put niScope EX multi record.vi with event structure including another program, what will happen? I would like to understand.
Message 1 of 1
(6,436 Views)
