High-Speed Digitizers
niScope EX Multi Record.vi
Hi:
I used niScope EX Multi Record.vi program. It will generate a random colour waveform. Sometimes it will generate a dimm colour and sometimes it will genarate the same colour again when the program run again. Is there anyway to make a dim colour to bright and not to repeat the same colour.
I am in a very urgent. I appreicate your quick reponse.
(7,003 Views)
Hi Nyborn,
The changes of the graph color are controlled by the Waveform Graph property node on your block diagram. In the niScope EX Multi Record.vi  example the Plot.Fill/PtColor value of the waveform graph property node is connected to a random generating number which changes the color on every execution. If you want to assign just one color, remove the random number vi and just wire a acii constant for the color you'd like. You can find listing of all acii color codes here.
I hope this helps.
Natasa
(6,989 Views)
Hi Natasa L. :
I have tried serval of your colour code. I found one and it looks good. See attached file. But there is only one colour. How can I take this only dimm colour off. Do you have any idea?
(6,971 Views)
Hi Natasa L. :
I still haven't heard from you. What is happening? Would you please email me?
John
(6,940 Views)
