High-Speed Digitizers
niScope EX Multi Record
Hi:
I have a question on niScope EX Multi Record. I tried to put 10ohm in the BNC cable. See my attached graph. Then, I press the "Bark" button on my test fixture. It will generate the waveform using the niScopeEX Multi Record vi. But, if I use 100ohm in R1 or 18kohm in R1, The program will not generate the waveform after pressing the "bark" button. But, if i press the "test" button on the fixture, no matter I use 10ohm, 100ohm or 18kohm, the niScope EX Multi Record vi will generate the waveform. What wrong with it? Is there anything wrong in the  niScopeEX Multi Record vi or is there anything that I can set in this program to solve this problem.
I am also attached the fixture block so that you can see the bark and test push button.
I am in a very urgent. I need your quick reponse. I appreicate your help
Message 1 of 1
(6,579 Views)
