High-Speed Digitizers
only fetching one channel
I am working in Visual C++; I have attached a simplified version of my code.  I'm using an NI5105 and trying to acquire 8 channels at 6MSa/s.  I am only capturing one channel, though.  If I use "0,1,2,3,4,5,6,7" I capture channel 0 (apparently); if I use "1,2,3,4,5,6,7" I seem to get channel 1.
I'm using a niScope_FetchBinary16 command in a modified FetchForever example code (please see the attached code).  My hardware can handle 160MB/s writes and I need the binary fetch to keep under that.
The obvious problem would be that I was not actually saving the data correctly, but I haven't found any problems with my save routine.  I'm hoping someone can spot a problem I can't.
The real code is a multi-threaded application (which I seem to need to do to handle the data rates), which is why I'm simplifying the code.  If I need to post the full code I will, I'm hoping there's a moderately obscure problem in the attached code though.
Greg
channelName =
"0,1,2,3,4,5,6,7";
verticalRange = 2;
verticalOffset = 0.0;
verticalCoupling = NISCOPE_VAL_DC;
probeAttenuation = 1.0;
minRecordLength = 1;
refPosition = 0.0;
numRecords = 1;
enforceRealtime = NISCOPE_VAL_TRUE;
minSampleRate = 6e6;
maxNumSamplesPerFetch = 800000;
// Open the NI-SCOPE instrument handle
handleErr(niScope_init(resourceName,NISCOPE_VAL_FALSE,NISCOPE_VAL_FALSE,&vi));
// Configure some common properties
handleErr (niScope_ConfigureVertical (vi, channelName, verticalRange, verticalOffset, verticalCoupling, probeAttenuation, NISCOPE_VAL_TRUE));
handleErr(niScope_ConfigureChanCharacteristics(vi,channelName,NISCOPE_VAL_50_OHMS,NISCOPE_VAL_BANDWIDTH_FULL));
handleErr (niScope_ConfigureHorizontalTiming (vi, minSampleRate, minRecordLength,refPosition, numRecords, enforceRealtime));
// Configure software trigger, but never send the trigger.
// This starts an infinite acquisition, until you call niScope_Abort
// or niScope_close
handleErr (niScope_ConfigureTriggerSoftware (vi, 0.0, 0.0));
// Start acquiring data
handleErr (niScope_InitiateAcquisition (vi));
// specify the number of waveforms
handleErr (niScope_ActualNumWfms (vi, channelName, &numWfms));
while(1)
   handleErr(niScope_FetchBinary16 (vi, channelName, 0.0, maxNumSamplesPerFetch, (ViInt16*)waveformPtr1, wfmInfo1));
   // please see alternative save attempt below
   fwrite(waveformPtr1,
sizeof(ViInt16),wfmInfo1[0].actualSamples*numWfms,ofFile);
   ProcessEvent();
// alternative save attempt
ViInt16* ptrData = ArgList.waveformPtr1;
for(int ii=0;ii<iChannels;++ii)
   fwrite(&ArgList.wfmInfo1[ii].actualSamples,
sizeof(ViInt32),1,ofFile);
   fwrite(ptrData,
sizeof(ViInt16),ArgList.wfmInfo1[ii].actualSamples,ofFile);
   ptrData += ArgList.wfmInfo1[ii].actualSamples;
   cout << ArgList.wfmInfo1[ii].actualSamples <<
" "; // this always shows the same number of samples for each Fetch command
cout << endl;
(6,820 Views)
So it turns out that in the long run, I am capturing data for all channels, but they are not syncronized.  Each file is a seconds worth of data, and what was happening is in the first file channel 2 wasn't recording data yet, but in subsequent files it showed up.  However, I still have a big problem because I'm running a frequency modulated signal into the two channels and the data is not lining up.
I'll search the forums for help on this, but any hints would be appreciated.
Cheers,
Greg
(6,791 Views)
The root question continues here...
(6,750 Views)
Hi Greg,
It is best to continue the issue in a single thread and Jeff has already performed some analysis on the issue so it can continue as linked above:
Can/Does the ni5105 perform simultaneous sampling on its channels?
http://forums.ni.com/ni/board/message?board.id=150&thread.id=2072
Steve B
(6,738 Views)
