High-Speed Digitizers
problem with NI5911 digitizer
Hi all,
I am acquaring signal through NI5911 digitizer, it acquires signal- during opration ,pc get hangs & error appers " TEMPARATURE STABLIZATION CIRCUIT NEEDS CALIBRATION ,Self calibration i have done, it passess without error
what I should do?
I am using Labview fulldevelopment 7.0,windows xp professional operating system.
thanks
RRYADAV
(5,978 Views)
You may have a problem with your computer, NI-scope or the board is not working.
If it is a computer or software problem you can the following:
1) re-install NI-scope
2) change the slot position of your 5911
3) try another computer
regards,
(5,964 Views)
