High-Speed Digitizers
problems installing PCI NI-5112
I had to change my measurement PC to a newer PC.
So I transfered my NI-5112 card to the new PC, but within this PC I contineously get a error -10840
Both PC run at XP SP2 with Labview 7.1 with the updated NI-DAXmx IVI 2.2 ....VISA and  NI scope 2.9.1
But in the old PC the card runs without error, new PC gives me this Error
Software error -10840.
What can cause these error?
(6,734 Views)
Please take a look at the following document and make sure you are not running into this issue, all tough I doubt that this is the problem in your case.
Error -10840 (or HEX 0xBFFA4001) with the PXI-5112
The key would probably be in the software versions between the two machines. could you compare the versions for both machines? especially Traditional NI-DAQ, NI-Scope, IVI and VISA.
If there are any differences then correct these so the new PC has the same software version as the old one.
Hope this Helps, regards
Karsten
(6,724 Views)
The software versions on both computers are exactly the same.
But unluckaly I've tried another card in this new PC and this worked without error's. this assumes that the software is fine.
(6,711 Views)
Hi Robert
Please contact your local NI Office here to discusses the issue with a Engineer and possibly start-up a RMA for your faulty board.
Kind regards,
Karsten
NI
(6,693 Views)
