High-Speed Digitizers
suggest me an acquisition card
Please suggest me an NI acquisition card.my requirments are as follows
PCI based
sampling rate >200 MSPS
bit resolution = 8 bit atleast
frequency bandwidth  >200 MHZ
input channels, 2-8
should sample on trigger and in continous mode as well.
(6,979 Views)
And one thing more i want number of sampling rate options at high sampling rates
i would like to hav at least 10sampling rates  between 100MSPS  to  200MSPS
please suggest an appropriate card
regards
umair
(6,978 Views)
Hello Umair,
Thank you for considering National Instruments for your data acquisition needs.  If I understand you correctly, you would like a data acquisition board that can sample at up to 200 MS/sec with between 2 and 8 input channels with 8 bits of resolution and at least 200 MHz bandwidth.  You would also like a data acquistion board that is capable of performing a continuous acquisition when triggered.  Based on these criteria, I have narrowed down the different PCI based high speed digitizers to three.  They are the PCI-5152, PCI-5153, and the PCI-5154. If linked each digitizer to their respective product pages for your consideration. Also, for more detailed information on all of the NI high speed digitizer offerings, I recommend that you browse the NI High Speed Digitizers Help document which I have also linked for your convenience. While the high speed digitizers mentioned above do not meet all of the requirements you listed; specifically the number of channels, they are the closest matches.
Best wishes,
Wallace F.
(6,958 Views)
thanks for ur suggestions.
 i will go through the specs of these choices and hopefully u wud be available for more queries.
thanking u again.
regards
umair
(6,940 Views)
Hello Umair,
I'm glad that I could be of assistance to you.  If you have any questions about the specifications, just post them to this thread and I will be happy to look into them for you.
Wallace F.
(6,927 Views)
