High-Speed Digitizers
vi version is too early (ag86100a.lbb, 5.1.1) to convert to labview 8.5
I'm not able to run the instrument driver vi for 86100 scope due to their early version 5.1.1.  We have 8.5 version.  Does anyone know how to fix or convert this?
Thx.
atl
Message 1 of 11
(15,589 Views)
You can download the CVI driver and use the Import Wizard to re-create the driver. It was an older version of the wizard that was used to create the original. If you don't have any version of LabVIEW earlier than 8.5, you could also post the old llb and ask if someone can do the conversion for you. It just has to be saved in 6.0 or greater for 8.5 to open it. Installing and using the wizard is probably the fastest way to get a driver you can load.
Message 2 of 11
(15,583 Views)
I have the same problem.  I am currently using LV9.0 and can't open the Agilent 86100a 5.1 labview drivers.  I have attached the .llb file to be converted.  If someone could do this for me, it would be most appreciated.
Message 3 of 11
(14,630 Views)
Hi JB,
I mass compiled you llb for LabVIEW 8.2.1 so you should be able to open it in LV 2009 now.
Message 4 of 11
(14,606 Views)
How can I get the file of "ag86100a_32.dll",who can answer for me ,thanks!
my email:kkk123747@sohu.com
Message 5 of 11
(14,311 Views)
It's probably in one of the downloads. I would try the CVI download first since the dll was probably created with that.
Message 6 of 11
(14,303 Views)
I have the same problem with JB. The VIs I have are in version 4.0.1, and the labview program I used is in version 2009. Is there any one can help me to convert them for me? That would be very appreciated.
Message 7 of 11
(12,974 Views)
Can any1 help to convert this version 5 Vi to a version which I can use in version 8.5? Thanks in advance. 🙂
Message 8 of 11
(12,867 Views)
Andylwk,
There is an official upconvert thread which can be found here: http://forums.ni.com/t5/LabVIEW/Upconvert-VI-Requests/m-p/1067230?requireLogin=False
Kyle Mozdzyn
Applications Engineering
Kyle M.
Message 9 of 11
(12,856 Views)
Hi all,
I got the problem to open Vi due to it is too eraly version. It may be version 5. I'm using version 8.5. Is there any one have earlier version to help me convert to comparable version 8.5. I really appreciate.
Harry
Message 10 of 11
(12,320 Views)
