High-Speed Digitizers
voltage range reached - but no error
Hello!
I have a problem. I neet to do a bodeplot very fast, and I just want to autoset my niscope yust when the maximum voltage of the range is reached. Or is there a possibility to set the voltage range manually? When the voltage reaches the maximum the value is always the same.
I use C++ with ni scope, no meassurement studio!
thank's Nick, Hannes
(6,268 Views)
you can configer your voltage range with niScope_ConfigureVertical() function. This is described in this help file: http://digital.ni.com/manuals.nsf/websearch/998C51E969F4900486256D9F007103F2?OpenDocument&node=132090_US
regards
P. Kaltenstadler
NI Germany
(6,246 Views)
