Hobbyist Toolkit
A ARM64 version?
Hi @Th.Menard,
Please can you post the latest output from the commands?
Message 21 of 25
(769 Views)
Sorry , I forget it
$ ps -Af | grep lvrt
root 23650 1 0 Mar14 ? 00:01:20 ./lvrt
tmenard 97363 97343 0 08:55 pts/0 00:00:00 grep lvrt
Message 22 of 25
(746 Views)
Thanks for the information.
lvrt is the LabVIEW chroot process. You may now be able to connect to the system from your LabVIEW PC.
Message 23 of 25
(733 Views)
Here is a link to a NI tutorial showing how you can create a LabVIEW project for the Rpi:
https://learn.ni.com/learn/article/getting-started-with-raspberry-pi-and-labview-community-edition#T...
Follow the instructions at step 4 - Explore an Example
Message 24 of 25
(671 Views)
@AndyLB Thanks for your research on this.
I think I've got packages added that will work on 64-bit Raspberry Pi OS, so this *should* just work now without having to do lots of custom commands and such.  There was a small change needed to get the Target Config dialog working now that there will be multiple packages available for each version.
For reference:
https://github.com/LVMakerHub/lvrt-deb-pkg/pull/19
https://github.com/LVMakerHub/LINX/pull/134
Message 25 of 25
(107 Views)
