Hobbyist Toolkit
About HC-SR04 ultrasonic distance sensor
Helloi I have Arduino UNO and HC-SR04 ultrasonic distance sensor. https://www.youtube.com/watch?v=kBHM1DzpcOU&t=95s. There is a video and there is a photo from this video's replies. I have same problem which photo guy had. I ran an arduino sketch and I saw the results also, the sensor works good. I couldnt find what Karthik found. Does any one know anything and  any solution about this situaton? Where is the edited version
(2,180 Views)
Have you solved this problem? I'm facing the same problem.
(1,815 Views)
Check out my post here:
https://forums.ni.com/t5/Hobbyist-Toolkit/Problema-de-lectura-de-sensor-ultrasonico-HC-SR04-con-libr...
Jorge Augusto Pessatto Mondadori, PhD
Sistema Fiep
CLAD, CLD
(1,793 Views)
