Hobbyist Toolkit
Arduino Due
How to make link to work with Arduino Due ?
(2,379 Views)
I believe you would be on your own to get this to work since Arduino Due is not supported.  There are plenty of microcontroller boards that are supported though, which would reduce you efforts to getting your first project off the ground... unless you want to add the ability to connect to Due, then by all means please do!
(2,216 Views)
