Hobbyist Toolkit
Arduino Max6675 Labview Linx Interface
Hello World! 🙂
this is Nino. First of all thanks for accepting me in this community!
I am trying to read the temperature of a K-thermocouple interfaced with a MAX6675 SPI, using Arduino and Labview.
However, I could not find any information / tutorial on how to make this project working and I have no Idea on how to do this.
I am using:
  1. labview 2019 64bit with the last version of LINX and VISA drivers
  2. Arduino Uno Rev 3
  3. MAX6675, K-type thermocouple
My MAX6675 is connected with the following PINs
  • SCK 10
  • CS 9
  • SO 8
Could you, please, post a working VI for this project or Post some instructions I can refer to?
Thanks in advance for reading my post and for your kindness
Cheers
Nino
Message 1 of 16
(10,948 Views)
Could you also send me a working  LabVIEWInterface.ino, configured for reading the MAX6675 shield, please?
Message 2 of 16
(10,894 Views)
Hello!
Unfortunatelly i do not have this solution made yet.
However there is an example of linx communication with arduino usint the PmodTC1 in the examples folder called LINX -PmodTC1.vi
the PmodTC1 also uses maximintegrated IC, but the MAX31855 instead of MAX6675.
I believe that with some of non work arounds you may be able to change that code to fit your needs.
Jorge Augusto Pessatto Mondadori, PhD
Sistema Fiep
CLAD, CLD
Message 3 of 16
(10,872 Views)
Thanks a lot, that was very helpful ! 🙂
Something I did not get is this:
To use the MAX31855 with PmodTC1 VI it is still necessary to modify the LIFA BAse?
Does it work just with the original LINX LIFA?
Message 4 of 16
(10,866 Views)
I tried out yesterday with another SPI chip, just changed the subvi parameters to set clock mode and channel, worked ok.
now i believe that you don't need LIFA anymore, since it has been substituted by LINX officially.
Sistema Fiep
CLAD, CLD
Message 5 of 16
(10,822 Views)
Could you send me your vi and explain which parameters should be changed, please? I'd just like to try ho it works..
Thanks for your time, I appreciate it very much
Cheers
Message 6 of 16
(10,809 Views)
Heyy Nino,
I was also searching for the same. If you found the answer, please share it with me also.
In the meantime what I did to make it work is, I uploaded the Arduino sketch for reading the temperature using the Arduino app and serial printed the temperature value. After that, I acquired the value in LabVIEW using a serial read from Arduino. And it worked well.
Just let me know if you require the Arduino sketch and LabVIEW vi.
Thank you
Ashq
Message 7 of 16
(10,694 Views)
actually i modify the pmod TC1.vi  and can read the temperature of max 6675 but i have  problem because i think i  have a error at the temperature convert
now i try to check the temperature with an other instrument to verify the data
Message 8 of 16
(10,192 Views)
actualy i am working on this vi
i have to check the temperature to verify that is correct but i think is ok
if anybody see a error please tell me
Message 9 of 16
(10,182 Views)
Thank you so much.
Message 10 of 16
(9,238 Views)
