Hobbyist Toolkit
Arduino Nano Linx with I2C and DO channels
Hi there,
i have a Labview programm running via LINX on a Nano which reads / wrutes data to the I2C bus. If i try to use the DO channels it works , but all the next quieries on the I2C bus fial because of a time out. The I2C does not work on the Nano. What is the background?
BR
Andreas
(2,956 Views)
can you post an image of your code or the .vi file?
Jorge Augusto Pessatto Mondadori, PhD
Sistema Fiep
CLAD, CLD
(2,884 Views)
Tha is the main,
one of the cases has the digital 1 chan / digital N Channels
So there is not much happening:
Open Linx, Open I2C, Read /write I2C and switch dig chan.
Close linx at end
(2,880 Views)
Considering the age of the Post, I think it has been resolved already.
However I want to point out that you are missing to close the I2C connection before closing Linx.
(2,379 Views)
