Hobbyist Toolkit
Build .so On RaspberryPi Target
I was looking at this article on building in the schroot. I noticed the instructions start with
sudo opkg update
but you'll get an error:
-bash: sudo: command not found
So, you can remove sudo (please update the doc) and keep trying but like in this thread, I see a whole bunch of missing libraries for example:
/usr/lib/gcc/arm-poky-linux-gnueabi/4.9.2/../../../../arm-poky-linux-gnueabi/bin/ld: cannot find crt1.o: No such file or directory
Is building on the target still supported? Where might I find some of those libraries. FYI I'm using LabVIEW 2020
(3,896 Views)
Accepted by topic author nanocyte
As you noticed the 'sudo' in some of the commands is totally unnecessary; that was just a mistake when that article was written.
As far as the other issues, this is happening because there is a mismatch in some of the versions of some low-level packages between the stuff on the target and what is present in the opkg package feeds.
I found that you can still make it work by running these commands after the ones listed in the article you linked:
opkg install –force-depends libc6-dev
opkg install –force-depends libgcc-s-dev
opkg install libstdc++-staticdev
Note that there are two dashes at the beginning of '--force-depends' (it's a little hard to see depending on the font).
(3,810 Views)
hi nanocyte, I have met the same question like you, but the reply doesn't fix my problem, here is my err info:
/usr/lib/gcc/arm-poky-linux-gnueabi/4.9.2/../../../../arm-poky-linux-gnueabi/bin/ld: cannot find crti.o: No such file or directory
/usr/lib/gcc/arm-poky-linux-gnueabi/4.9.2/../../../../arm-poky-linux-gnueabi/bin/ld: cannot find crtbeginS.o: No such file or directory
/usr/lib/gcc/arm-poky-linux-gnueabi/4.9.2/../../../../arm-poky-linux-gnueabi/bin/ld: cannot find -lgcc
/usr/lib/gcc/arm-poky-linux-gnueabi/4.9.2/../../../../arm-poky-linux-gnueabi/bin/ld: cannot find -lgcc_s
/usr/lib/gcc/arm-poky-linux-gnueabi/4.9.2/../../../../arm-poky-linux-gnueabi/bin/ld: cannot find -lc
/usr/lib/gcc/arm-poky-linux-gnueabi/4.9.2/../../../../arm-poky-linux-gnueabi/bin/ld: cannot find crtendS.o: No such file or directory
/usr/lib/gcc/arm-poky-linux-gnueabi/4.9.2/../../../../arm-poky-linux-gnueabi/bin/ld: cannot find crtn.o: No such file or directory
collect2: error: ld returned 1 exit status
Makefile:10: recipe for target 'libadd.so' failed
make: *** [libadd.so] Error 1
could you tell me how to solve this problem.
(3,055 Views)
