Hobbyist Toolkit
Custom Command-- in DHT-11 Read VI
There is "DHT11 Read" VI in LINX for LV 2020, so I try to use this.
Inside this VI, it calls Custom Command.vi, and the Context Help says, you must add custom command to the LINX firmware...
So I follow this:
https://www.labviewmakerhub.com/doku.php?id=learn:tutorials:libraries:linx:misc:adding_custom_comman...
But in LV 2020, I don't have this:
MakerHub –> LINX –> Generate Firmware Libraries
Would you suggest what should be next?
Thanks.
(3,353 Views)
Try Tools > MakerHub > LINX > LINX Firmware Wizard... > pick correct board settings > Click on Settings > Confirm Correct Paths > Click on Generate
Should say "Done!" in a pop up window and now the files you can open and edit should be in the appropriate directory.
Does that help?
(3,316 Views)
Hello
i meet the same issue by using le dht 11 sensor with an arduino Uno.
it gives " time occured error..."
'erreur 5001 s'est produite à : :
DHTRead.vi >>
Custom Command.vi >>
Send Command.vi
I manage it two years ago so it functiun with one arduino card but with another one, i can't do it again.
Could someone help me please? don't remenber how to solve this issue.
Olivier
(3,011 Views)
