Hobbyist Toolkit
Deploying a RTexe on a Raspberry 5 with cDAQ
Hello everyone,
I'm wondering if, through the Hobbyist Toolkit, it is possible to deploy executable on Raspberry Pi 5 (set as startup) that via cDAQ executes a simple acquisition and control task. In other words, the idea would be to use the Pi + cDAQ combo as a less-powerful substitute for a cRIO, i.e. able to execute code as a standalone solution.
I understand that the toolkit is OK for simple GPIO applications, but I am not sure if that would work with an additional piece of hardware like a cDAQ, and if it is not the case, it would save me loads of time to just know it beforehand. Any help/insight/suggestion in this regard will be highly appreciated.
Thanks!
Marco
Message 1 of 1
(576 Views)
