Hobbyist Toolkit
ERR 5001 with LINX and arduino UNO
Hey,
I am running a simple vi where a led is controlled via arduino.
For this I use an arduino UNO, LabVIEW 2020 32-bit version and LINX. This works correctly, but after going through the while loop a few times (sometimes 2, sometimes more than 10 times) I get ERROR 5001.
With highlighted execution I do not have that problem. There is already a 100ms delay in the while loop. Any suggestions?
(1,374 Views)
I don't think I can help, but a question.
I have the same Labview community edition 2020 and install Linx toolkit but it does't work.
After I read that the community edition has alread installed Linx toolkit. Maybe I destroyed this toolkit.
The package install stop ERR 5001. I install Arduino IDE intall 2.3.3.
How do you gets it running?
While installtion did you had plug in the Arduino board?
Thanks for reply
ML
(1,170 Views)
