Hobbyist Toolkit
Installation fails: LabView 2020 Professional with Raspberry Pi Model 3 B+
The Raspberry Pi OS version that I used that works can be downloaded from here.  I specifically used the Raspberry Pi OS (32-bit) with desktop Version: August 2020 Release date: 2020-08-20.
I would recommend that you use the LabVIEW 2020 Community edition as you do not need to install anything else to get this version to work.  If you did install a different Version of LINX then you may have messed up the installation and the only way to fix it is to reinstall LabVIEW 2020 Community edition.
If you are still having issues please provide details of your setup.  If you are using LabVIEW 2020 Professional like the original topic of this post, please check my post on this topic which lists the software that I had to install to get this to work.  Note, this is only required for LabVIEW 2020 Professional.
David Wilt
The New Standard LLC
Message 11 of 18
(2,848 Views)
Una ligera corrección en el link ahay que eliminar la coma, si no no te lleva a la descarga.
SAludos
Message 12 of 18
(2,847 Views)
Hola nuevamente, si el link anterior no funciona o descarga otra imagen que no sea la strech, puedes usar el siguiente: https://downloads.raspberrypi.org/raspbian/images/
En este puedes seleccinar directamente la imagen, tambien del sitio oficial de Raspberrypi.org.
Saludos.
Message 13 of 18
(2,847 Views)
Buenas Kike / David,
Sigo con el mismo problema.
Tengo instalado esa versión de LabView
La imagen que instalé de raspbian fue esta
El mensaje que siempre me sale es este en el LabView 2020
Conecta con la Raspberry Pi 3B perfectamente
Y si te refieres a esta como, no la puedo quitar.
Saben donde puede estar el problema.
Gracias de antemano
Un saludo a todos
Message 14 of 18
(2,813 Views)
@johnleon63 please provide a screenshot of the packages you have installed under VIPM.  It sounds like you do not have the correct version of LINX installed.  It sounds like you have the 2014 version installed and not the 2020 version.  Here is the version you should have installed and no other LINX versions.  If you have both it could be causing your issue also.
VIPM Raspberry Pi ProjectVIPM Raspberry Pi Project
Note: You don't need the WebSockets package I also have installed as shown in the image.
Thank You,
David Wilt
Message 15 of 18
(2,792 Views)
Hola David,
Ahora todo perfecto,.
Tuve que desinstalar todo y volver a instalar lo que sugerías y pude cargar el programa a la Raspberry.
Lo dicho, muchas gracias, es un placer contar con gente como ustedes.
Un saludo.
Message 16 of 18
(2,775 Views)
Buenas otra vez David y perdona por ocupar tu tiempo.
Ahora tengo problemas al intentar pasar un VI a la tarjeta, no me deja conectar con ella dentro de un proyecto.
Y solo tengo instalado el LINX Toolkit como ves
Me puede orientar y corregir donde puede estar el error.
Gracias.
Un saludo,
Message 17 of 18
(2,742 Views)
Spoiler
sudo apt update
sudo apt full-upgrade
Message 18 of 18
(1,955 Views)
