Hobbyist Toolkit
Linx license usage
Now that the linx library is now supported by NI, I would like to know if the licence now allow commercial usage of this toolkit.
Thank you in advance for your answer.
(3,217 Views)
Accepted by topic author RaphaelFortin
Linx never was preventing commercial use. The LabVIEW Community Edition which comes with Linx installed, does! If you have a fully licensed Professional LabVIEW license, you are fine to use Linx for your commercial development. If you should do that is a different question. I wouldn't consider the normal Raspberry Pi an adequate hardware. It's SD card based storage is bound to fail sooner or later. With a Compute Module things look a lot better.
Rolf Kalbermatter  My Blog
(3,213 Views)
Thank you for your fast response. We do have a proffesional license. We only wanted to know if this library was possible to use in future projet.
(3,204 Views)
I second this answer.  This question was actually asked to NI and a response was provided saying such.  The repose is documented in a presentation which can be found here on page 7.
David Wilt
The New Standard LLC
(3,189 Views)
