Hobbyist Toolkit
Linx with Raspberry pi 3 A+
Hi everyone.
I want to carry out a project in Rpi 3 A + and I was wondering if it was possible to load code onto these boards using LINX and leave a program made in Labview inside the Rpi running autonomously.
(2,760 Views)
Accepted by topic author Choke
Yes, you can deploy code to a Raspberry Pi to run headless with LINK.
David Wilt
The New Standard LLC
(2,750 Views)
I've used the PI 3A + with LabVIEW community edition and the latest PI OS. You can deploy applications.
It is best if you can put a heatsink on the CPU. The PI 3A + may throttle the CPU speed.
Cheers,
Andy.
(2,727 Views)
Very friendly as always.
Total thanks
(2,696 Views)
