Hobbyist Toolkit
Not able to install the LabVIEW 2016 Add-on
I need to install MakerHub Linx for Arduino add-on in LabVIEW 2016 and I keep getting an error because the latest version is compatible with LabView 2020 and not LabView 2016.
How can he download the Add-on for LV 2016? Any help is greatly appreciated
(1,615 Views)
Accepted by topic author Tester17
You can't! There is a Linx Toolkit for LabVIEW 2014 and the new one for LabVIEW 2020. There was a Beta for LabVIEW 2019 but nothing in between. The Linx Toolkit makes use of some mechanisme that is also used in LabVIEW realtime and that is absolutely LabVIEW version specific. This part of the Linx Toolkit must match the LabVIEW version specifically and can't be mixed and matched with other LabVIEW versions just like you can't install LabVIEW Realtime 20xx into LabVIEW 20yy.
Rolf Kalbermatter  My Blog
(1,590 Views)
