Hobbyist Toolkit
Raspberry Pi Target Configuration
Hi Jeff,
Thanks for your message. Hope you're able to access the serial port OK.
I've ported most of the LINX device code to the Raspberry Pi Pico. I have it running on boards with the RP2040 and RP2350 microcontrollers.
It supports GPIO, I2C, SPI, servos, pwm, square wave output, analog input and neopixels.
I hoping to have a beta for the community to try soon!
Many thanks Ken for adding LINX support for the 64 bit version of Pi OS 🙂
Andy.
Message 11 of 13
(1,145 Views)
wait, 64bit OS is supported now?
I am going to have to burn a new PI image to try on my Pi5..
Your VISA UART code was helpful and my stuff is now working. I have an bash file that runs to copy files, but it does not seem to do a very good job so I need to work on figuring out how to detect a USB drive being inserted in a PI with LabVIEW, but lower on my priority list.
Thanks for the help
Jeff D.
Certified Architect LabVIEW Champion DQMH Framework
Message 12 of 13
(1,047 Views)
Hi Andy!
I'd be really interested to use/test your version for the RPi Pico!
Do you have an idea on when the beta will be available?
Message 13 of 13
(987 Views)
