Hobbyist Toolkit
Raspberry Pi with Labview 2020 Sp1 Linx Installation Failure
For the past couple of days, I've been unable to install Labview Linx 2020 on my Raspberry Pi Compute Module 4. Despite it connecting and seemingly downloading all the packages, the install always gives me this failure and I don't know how to fix it. I've tried manually installing it as well, but the linx executable will never appear as running no matter what I try. I've also tried flashing the Pi's emmC with a preinstalled version of Labview 2020 but get the same error. Below is the log and attached is the activity after my tries at manual installation, as well as my OS details (manually reverted to buster for compatibility).
Log:
Connecting to target...
Successfully connected to target.
Successfully connected to the target.
Target configuration updated.
OS Version: 10.13
CPU: BCM2711
Systemd Version:
Has Internet Access: True
Device Type: Raspberry Pi 2 B
blacklist spi-bcm2708is not present.dtparam=spi=on already exists.i2c-dev already exists.i2c-bcm2708 already exists.blacklist i2c-bcm2708is not present.dtparam=i2c1=on already exists.dtparam=i2c_arm=on already exists.
Adding MakerHub feed...
MakerHub Feed Already Exists
Updating package index. This may take over 30 seconds depending on your internet speed...
Ign:1 http://feeds.labviewmakerhub.com/debian binary/ InRelease
Ign:2 http://feeds.labviewmakerhub.com/debian binary/ Release
Ign:3 http://feeds.labviewmakerhub.com/debian binary/ Packages
Ign:4 http://feeds.labviewmakerhub.com/debian binary/ Translation-en_US
Ign:5 http://feeds.labviewmakerhub.com/debian binary/ Translation-en
Ign:6 http://feeds.labviewmakerhub.com/debian binary/ Translation-en_US.UTF-8
Hit:3 http://feeds.labviewmakerhub.com/debian binary/ Packages
Hit:7 http://archive.raspberrypi.org/debian buster InRelease
Hit:8 http://raspbian.raspberrypi.org/raspbian buster InRelease
Reading package lists...
Installing LabVIEW...
Building dependency tree...
Reading state information...
lvrt20-schroot is already the newest version (20.0.0-4).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Rebooting Target...
Checking target status...
Installation failed. If this is the first time the installation has failed try again. If this error persists search, then post on the LabVIEW MakerHub forumsat labviewmakerhub.com/forums/linx.
OS Version: 10.13
CPU: BCM2711
Systemd Version:
Message 1 of 1
(430 Views)
