Hobbyist Toolkit
Resetting Arduino Labview Connection when Abrupt Stop
When you press the stop button in Labview or unexpectedly disconnect, the Arduino is still connected via LINX. When trying to reopen a connection to the Arduino via LINX it will fail. Is there any way to forcibly close the LINX session prior to starting a program in the case that there is an unexpected disconnection.
(2,076 Views)
Anybody know the answer?
(1,995 Views)
i understand that you are not closing visa session, can you share your code so we can see what is going on?
Jorge Augusto Pessatto Mondadori, PhD
Sistema Fiep
CLAD, CLD
(1,992 Views)
