Hobbyist Toolkit
Send sequence values (T/F) to different leds connected to arduino
Hello, thank you for reading me, I´m trying to do a 3 led sequence and send it to a arduino with also 3 leds but the sequence is not working on the physical leds
(1,943 Views)
Basic dataflow problem!
Your sequence runs in parallel the the DAQ train, each runs once per iteration of the while loop. You don't need any local variables at all here!
(1,927 Views)
Your ABC should not be controls if you are using them as indicators (to be changed by the code instead of the user.)
I don't have your hardware, but here's a quick draft. (I am sure things can be simplified quite a bit more).
(1,922 Views)
just got the code, and added linx
Jorge Augusto Pessatto Mondadori, PhD
Sistema Fiep
CLAD, CLD
(1,900 Views)
