Hobbyist Toolkit
'The Unknown is not a supported LINX target'
Hi There!
I'm trying to install LabView on to a RPi4 and I just can't get it to work. Here's what I've tried:
Using Raspberry Pi OS:
  • 64-bit
  • 32-bit
  • Legacy, 32 bit
I can communicate with it fine with Putty. I am using a 64GB SD card.
I'm currently using the Legacy 32-bit, and I get all the way to the end of the process then when I try to 'launch example' I get this error message:
any guidance is sincerely appreciated!
(1,363 Views)
Can you provide more information?  What version of Raspbian are you using?  What version of LabVIEW are you using?  Any other details about how you're installing things or any other error messages you're seeing would be useful.
Have you tried using a version of Raspbian with LabVIEW pre-installed?  Details here: https://github.com/MakerHub/LINX/wiki/Installing-an-image-with-LabVIEW-pre-installed
(1,325 Views)
Hi Ken_S,
Thank you for your reply! I did switch to the pre-installed SD card, you can follow my trials and tribulations here! Re: New experimental LV RPi/BBB installation feature now available - Page 2 - NI Community
Thanks again,
(1,311 Views)
