Hobbyist Toolkit
Using multiple sensors together with linx
Hi guys,
i am a very beginner in with labview and linx and i want to build up a motor control via accelerometers. Therefore i would like to use two accelerometers together with arduino uno. Unfortunately i can only find instructions for the use of one mpu but no explaination for the use of multiple sensors/actors. Can you help me how i can build up this?
best regards,
Audnread
(2,308 Views)
Hello Audnread, and Welcome!
Since I2C is a bus serial communication, you can just use multiple read and write nodes from linx in your VI.
Usually to help, we need a bit more information such: what are your requisites? are you using different i2c channels? do you know how to set up slaves adresses?
i will assume that:
you are using an arduino UNO, using only i2c channel 0, and different slave adresses (if not then you need multiplexing)
i do not have here 2 mpu 6050 (for example) for testing, but i do have a GY-80 that contains different slaves.
Also, i could use pre built VIs to initiate communication and read registers, but i opted not, in order to be very didactic.
i created a very simple VI for you. Please let the community know if that worked out for you.
here are the information on this gy-80 sensor board: https://www.nskelectronics.com/gy-80_-_multi_sensor_board.html
Jorge Augusto Pessatto Mondadori, PhD
Sistema Fiep
CLAD, CLD
(2,250 Views)
