[IDLE] தமிழினி
Internal Error in TestStand while analysing sequence
Hi All,
I am facing the Teststand Internal Error while analysing the sequence.
Unable to clear this error even with Labview Adapter configured as dev.
Teststand Version : 2016
Sricharan
(3,060 Views)
What happens if you ignore the analysis?
Try reinstalling Teststand, as the error says its internal error.
அன்புடன்
தமிழ் நேரம்
முதல் இந்திய ஆய்வுமெகபொப சிற்பி
சோதனைநிறுத்தம் சிற்பி
மற்ற சான்றிதழ்கள்
யாதும் ஊரே! யாவரும் கேளிர்!!
(3,039 Views)
Hi Anish,
The same sequence was analyzed previously in my system.
But after one custom step update i am facing this internal error issue.
But the same sequence is working fine in another system without internal error
(3,016 Views)
