[IDLE] ALVIN
What topics would you like to see discussed at ALVIN?
Start a separate reply for each different topic; reply to an existing reply if you would like to see that topic also.
(10,548 Views)
I'd like to see a presentation on source code control, with an emphasis on Subversion and using the Viewpoint Systems VSI TSVN Toolkit.  An example of how to branch and merge in LabVIEW would be especially useful.
(8,964 Views)
I'd like to see a presentation on X-controls: what they are and what they are good for.  Wes Willis covered them at the May ALVIN meeting, but I'd like to see more.
(8,964 Views)
I agree. I would like to take it a step further and discuss ways to track and back up entire projects, setting in MAX and other VIs that are not directly linked to the project.
(8,964 Views)
If a presentation on Xcontrols is given, then the perfect follow-up to that would be a presentation on Xnodes the following months.  Best to keep them back-to-back, since they have a relationship.  However, Xnodes are an advanced subject, and they are not supported by NI.
~Tim
(8,964 Views)
