[IDLE] Calgary LabVIEW User Group Community
conditional structure
I realize my end of study I'm beginner in labview my defense June 8 please help me.
I have a the following programe.
  25 compared with a random number (in the example nome x)
   if 25 <x then
     dialoge box display "supperior x 25"
if 25 <x <30 alores
    box display dialog "is a good choice"
if x> 53 then
display dialog "x will be recorded"
how I develop this program with labview
  cvp help me it's urgent
this is exactly what I needed thank you for your ashbeigi Shamloo also help.
my problem I acquired I want to compare the temperature of VAL with other integer and I want to save the result into a text file but its not working
  watch
(14,336 Views)
Hi Pierre,
A case structure with a little bit of logic before it (using things from the comparison pallette for instance) will give you what you want:
See the video below for how to use them:
http://www.youtube.com/watch?v=cgS3u0nupfs
More info
http://www.ni.com/gettingstarted/labviewbasics/exestructures.htm#Case Structures
For multiple ranges you can nest case structures. Here is an example:
https://decibel.ni.com/content/docs/DOC-3507
Ash Beigi
Academic Technical Sales Representative
National Instruments - Electronics Workbench Group
(10,128 Views)
Here is the LabVIEW code without random generator (it makes it easy to test the code):
and the following is the code with random generator:
Pleaes try to explain you problem clearly. The question was vague and hard to understand. Is your psudo code correct? (check it again.) I wrote this code according to your psudo code. Consequently, the program shows two dialog boxes if the number is 26 as it satisfies the first two conditions.
(10,128 Views)
I checked your VI. The problem is that you have put the "Open/Creat/Replace File" VI and "Close File" VI inside the loop. They should be out of the loop if you want to record all of the data produced through the loop iterations.
You don't need to use "Set File Position" VI.
You may use the following code which records some numbers on hard disk in a text format. You should replaced the random generated number VI with your temprature measurments:
If you find this post useful, please click on the "like" button at the bottom of the post.
(10,130 Views)
