[IDLE] Central Texas LabVIEW User Community
Determining the Power Consumption of a PXI System
When configuring a PXI system, a key factor to consider is total power  consumption, which ensures proper system performance and guarantees the safety  of the equipment.
A power budget is a measure of how much power is  consumed by a PXI chassis and the components within the chassis. The budget  takes into account the capacity of the power supply in the PXI chassis at a  given temperature, as well as the power requirements of all components in the  system. Efficiency is also a key element of the budget in order to compensate  for real-world performance of electrical equipment and variations with  time.
This application note discusses the importance of performing a  power budget calculation on a PXI system. A power budget will predict the  behavior of operation before the system is used. Oftentimes, unexplained reboots  or an inoperable system can be avoided by better understanding the power  consumption. This paper describes common use cases on how a power budget is  helpful, as well as methods and considerations for properly determining the  power budget. The goal is to verify that the PXI equipment will function  properly and to document power consumption for future use.
Overall, this  paper addresses the following questions:
  1. Why is it important to determine a power budget before configuring your  system?
  2. How do you determine how much power your system requires?
  3. What considerations should you make when setting up your system?
Full story below:
http://zone.ni.com/devzone/cda/tut/p/id/3243
Message 1 of 1
(4,138 Views)
