Dallas User Group Community
High-Density Switching Solutions to Streamline Automated Test Annouced
National Instruments today introduced the NI SwitchBlock for PXI,  a high-density switching solution featuring an innovative architecture  that simplifies connectivity through internal column expansion. Designed  specifically for demanding automated test systems with large numbers of channels, the NI SwitchBlock integrates with NI Switch Executive switch management software to provide a streamlined, intuitive option  for switch configuration, routing, programming and maintenance.
The NI SwitchBlock comprises an expandable carrier that occupies four  PXI slots and accommodates up to six relay cards. Engineers can use the  carrier’s integrated high-voltage analog bus to internally expand the  relay cards into large matrices, with more than 2,000 crosspoints in a  single carrier. They can further expand these matrices with an NI  SwitchBlock expansion bridge, which extends a carrier’s analog bus to  additional carriers. Engineers can combine up to four NI SwitchBlock  carriers to create internally routed matrices with as many as 8,832  crosspoints in a single PXI chassis. Because of this innovative hardware  architecture, the NI SwitchBlock can integrate with other PXI  instruments and I/O for use as the core of large-scale automated test  systems.
With NI Switch Executive software, engineers can graphically configure  their switch systems one relay at a time for total control, or  automatically route signals across multiple relay cards simply by  specifying endpoints. This high level of abstraction helps engineers to  quickly and efficiently begin developing their application. By combining  NI Switch Executive with NI LabVIEW graphical system development software, engineers can abstract numerous  route groups to easily configure, program and maintain large matrix  configurations. The NI SwitchBlock also includes the new NI Switch Health Center software, which increases long-term system reliability by automatically  running onboard diagnostics that verify relay continuity and display  relay count information.
Additionally, engineers can combine the NI SwitchBlock with mass  interconnect solutions from MAC Panel and Virginia Panel, which provide a  single rugged connection point between multiple NI SwitchBlock  connectors and a test fixture. This further simplifies wiring for large  matrix configurations and helps engineers streamline hardware  integration and reduce test setup time.
The NI SwitchBlock offers multiple relay card options, including a  growing selection of topologies and relay types to address a variety of  large-matrix test needs. Engineers can custom configure the NI  SwitchBlock with different relay cards in a single carrier to create a  configuration that best meets their requirements. To help engineers find  the most efficient NI SwitchBlock configuration for their specific  application, NI has created an online advisor tool that guides them  through the relay card selection process and adds the correct number of  carriers and expansion bridges to meet their application requirements.
Message 1 of 1
(7,197 Views)
